Hi there!
Any clue about how to fix this issue?
You are making use of a font (Dubai Medium) which is not installed on the ShapeDiver servers. I checked and this font seems to be free for commercial use, I will add it to the list of requested fonts for installation. In the meanwhile, unless using this specific font is crucial for your application, you can switch it to a different one.
If you are not sure where your definition makes use of this font, you can save the file as .ghx and look for “Dubai” in a text editor, it will show you which component or text panel is set to use it.
Hi Mathieu,
Thanks for the workaround! I was working with another developer’s script, and it was quite difficult to locate the specific panel using this font. Your suggestion really helped streamline the process.
I’ll switch to a different font for now while waiting for the installation. Appreciate your support!
