Arial in GH does not match with font in shapediver
HI
We created a file with an optional text input and wanted to use arial as a font. the Fontlist in GH shows 0 as the index for Arial. which leads to the wanted result in GH. in the uploaded version on shapediver it unfortunatelly shows a complete different font though.
ANy Ideas which index Value could work or what we did wrong?
THanks in advance
Yannik
The list of fonts installed on ShapeDiver systems does not necessarily match the ones you have installed locally, therefore you cannot assume that giving a specific index from the list will result in the font you expect. If you already know the name of the fonts you want to use, you could directly send them to the Font component of Squid. You can check the fonts installed on the shared ShapeDiver systems here: Which fonts are supported on ShapeDiver?
