Running the latest Rhino 7 candidate release on a Mac.
Having an issue when using the Flow command where the Stretch function isn’t closing curve.
I have an open profile curve as the source that is the same length as the base curve and closed path curve. When I execute the command with and without the Stretch option, it’s not “stretching” the curve. It was working in the previous candidate release but with different closed curve dimension. After updating to the latest, doesn’t seem to be working.
Attached a video of the issue.
I tried the other Flow options in conjunction with Stretch but no luck.
Thanks
Uploading: Screen Recording 2022-02-07 at 2.11.27 PM.mov…
