Whenever I handle larges Mesh Objects in Rhino 6, my computer tends to crash. I am relatively sure it is caused by my graphics car (Radeon Pro WX 4100) as at first Rhino crashes, then the GUI. The only resolve is then to do a hard reset of my HP Z4 Workstation.
This is a really annoying problem and kills my productivity as I need Rhino to edit Mesh Objects. Is there anything I can adjust in my Rhino settings to counter this problem?
If the entire operating system is crashing, this is almost certainly a crash in the GPU driver. Have you tried updating your driver to the latest available?
I am using the latest AMD Enterprise Drivers from 23/05/2018. If the drivers are the only factor in this story, then I’ll have to wait for the new driver version.
Is there anyway I can help Mcneel in diagonising or something so maybe you guys can relay it to the devs at AMD? Or is there anyway I can force my system to create a crash report? Because there is no info whatshowever generated
Yep… I would try rolling back to the 17.Q4 drivers and see if things are any better. I’m still working with AMD on the 18.Qx drivers issue…hopefully hear something today.
It seems to be working for the moment. I will update this post/report back EoB.
EDIT: about 11 business days later… I can report Rhino is still working flawlessly with the 17.Q4.1 drivers. So anyone reading this: The 18.Q2 drivers are not OK for Rhino 6, so hold your horses and revert to 17.Q4(.1) and see if future drivers are the solution as per recommendations by @jeff
Thank you all for the rapid respons and excellent support, as always :). This tight community is one of the reasons I Always like to spend my money on McNeels products !!
