Fillet brep-choose edges
Hi everybody! :wave:
I created brep and want to fillet edges, in result after solid difference I want to create brep2.
But I have some problems - cant choose edges because they are all out of order
How can I get corner curves after deconstruct?
error 18-06-23.gh (150.0 KB)
Have a look at this monstrosity.
error 18-06-23.gh (154.8 KB)
It would have been better to create the brep (roadway?) differently, by using your sketch as a section curve with Sweep 2. Or orienting your sketch on the rails and lofting them.
Trying to fix it at this point is far from the best way.
Agreed.
There is a less painful way.
This should be a default function of GH.
A video instead of GH code? NO!
This is ridiculous reverse engineering.
roadway_RE_2023Jun18a.gh (168.2 KB)
error 18-06-23 Edited V0.gh (151.3 KB)
if you say so…
Useless.
missing
You will attach that plugin snapshot in your reply, I knew that! :sunglasses:
Use Lasso selection in pOd Pick.
