I want to fillet the sharp interior of this surface in grasshopper. The number of rows and columns i have set on a slider. How to I pull out just the vertical numbered edges so i can fillet them.
Thank you for your help!
Hi @Victor_Czulak,
Here’s one way, you can exploit the project component and check the curve length. If an edge is truly vertical (0,0,1) it will have a 0 length curve when projected to the xy plane.
Hope that helps!
Graph Space:
Model Space:
So I got this set up the way I think you have but, however it is still throwing an error. I attached the GH file and my problem area is highlighted in the group.
Paint Rack.gh (23.7 KB)
Wow that did it! Thank you so much I would have never solved this on my own!
Or without posting your GH file and geometry.
I always forget about this one thanks
