I created a file yesterday and was using RhinoRender to generate renderings and a material palette.
Today, when I go to open the file, the Rhino application freezes and says “Loading Rhino Render, version 1.50, Mar 19 202, 23:54:52” in the command dialogue box. It stays stuck on this until I have to force close the program.
Is the file corrupt? If so, is there a way to troubleshoot it? The .bak file similarly doesn’t load.
Hello - thanks - nothing leaps out at me… the video drivers are a little old-ish, but that does not seem like it would cause this. My guess of the moment is that there may be an object in the file that does not want to create a render mesh and gets stuck at that stage if there is a shaded or rendered viewport in the file. Doe the file open if you start Rhino in Safe Mode?
To start Rhino in Safe Mode: Windows start menu, type in ‘Rhinoceros’ and look for the ‘Rhinoceros in Safe Mode’ entry.
You can send us the file for a look - www.rhino3d.com/upload. Please put a link back to this topic in your comments.
Hello - thanks, I got it - the file opens instantly here and shades/renders as expected… Are all the materials and textures you added from a local file or are they on a network drive or a synced drive like dropBox or Google Drive?
Thanks, that all looks correct, to me… Is this a new installation of Rhino? I’ll ask some bigger brains here but can you try doing a repair of the Rhino install? Windows Start menu > Settings > Apps > find Rhino 6, select it and click Modify then Repair…
Hi! I have this exact issue but cannot open the file at all to remove the materials. Is there another way to get it open? Am in a bit of a deadline emergency! Thanks
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 24Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 675MX (NVidia) Memory: 1GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
> Accelerated graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\Jed\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
I get loading v-ray for rhinos version 6.00.03 and loading legacy rhino render version 1.50 . Its just keep loading i have to forcefully stop and still the file won’t open . Its a 3dm file
