File is millimeters but dimensions are fractional inches?
I can’t figure out why Rhino is putting fractional inch dimensions on my… dimensions :slight_smile: when my doc is in millimeters.
Saw there is a setting for this, but I can’t seem to find it.
thanks
Thanks - I’ve done that, but a 14mm dimension still shows up as .55 :
What are your file units?
And 0.55 is decimal, right?
I think it’s exactly as you’re showing:
And when you select the dimension, what does the properties panel show?
Yes - that was it, thanks. I don’t know why that needs to be changed separately but whatever.
Only issue is the size - again, not sure why it doesn’t just adapt:
big-dimension
Hi Andrew -
Adapt to what?
Please post a 3dm file.
Hi Wim,
I’m not at my computer at the moment.
Adapt to the current text size. I just want to change the dimensions to mm from inches, not the size of the text. My 1st image shows the dimension text at the default size.
I don’t understand the scaling - with the drawing at millimeter scale, I’d think the text, at a factor of 1, would be 1 mm high. Not sure though.
Hi Andrew -
That’s fine. Just post the 3dm file when you get to it.
Morning Wim -
Here you go.
dimension text sizes.3dm (35.8 KB)
Hi Andrew -
I’m not sure which factor of 1 you refer to. There are two dimensions in your file, with each a different annotation style.
The big dimension is using the “Template Millimeter Large” annotation style:
The font is defined to be 3.5 units high and to be scaled by a factor of 100 when used in model space.
The small dimension is using the “Inch Decimal” style with font height 0.125 scaled by 10 in model space:
What is it that you are trying to do?
Thanks Wim - got it. I had to change the default annotation style, but expected it to “default” to the last selected style.
