I’m having trouble saving a setting in the Options menu.
Specific issue is with the setting of Options>Files>Imported File Layers.
Default is “Use complete layer tree from source file”
Alternative is “Use existing layer tree from source file”
Change doesn’t stick after "ok’ (reopen options and it’s the same as before)
Also doesn’t stick when switching tabs without closing out of options. In fact, it glitches, showing both as selected (see attached image)
I just upgraded to 6.5 (from 6.4), but had not tried this before, so I’m not sure if the issue was present in earlier builds, or a new change.
System Info:
Rhino 6 SR5 2018-5-8 (Rhino 6, 6.5.18128.14431, Git hash:master @ c9d527277610c285bc57477182b5b0189a20a317)
Licence type: Commercial, build 2018-05-08
Windows 7 SP1 (Physical RAM: 16Gb)
Quadro K1100M/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 369.49)
Thanks!
