hello,
I was importing .obj files into rhino when in one instance I clicked the ‘always use these settings’ button and now the dialog does not open. Is there a way to recover this dialog box? I want the options back. thanks
when you are going to import a file again, below the file name you have the options button, then you can enable the dialog again.
thanks a lot this helped! I was so used to dragging and dropping to import that I didnt’ realize there is a button from the menu! thanks
Has this changed? I am having the same issue but I do not have an options button.
It’s on the dialog where you enter the file name and choose the file type.
Thanks. I realized I had to specify the file type when importing to get the options dialogue to appear.
