Even in V7 WIP, I noticed that the window layout, always record history option, tool settings (like naked edges for the edge analysis panel) and especially display modes (which can only be imported one-by-one unless you use scripts) don’t get imported when you do “import options” with “select all” (and of course, toolbars are also a separate import).
This is problematic if you want to deploy Rhino with the same settings across a company network.
Anyone ran into this where they work? How did you avoid running around to everyone’s PCs and manually setting them up?
