Tools > Import options does not load settings correctly
Hi all,
To copy options to our users I created view settings for wireframe and rendered mode. I export options and then load them.
I import options, but the rendered view does not update. Only after I go to tools => import options and press OK. I do not change any settings, just open settings and close.
Example gif:
Hereby the settings file:
Rhino_Settings.ini (151.9 KB)
Probably a minor bug?
Checking it, thanks.
I reported quite awhile back that OptionsImport was fairly broken in V7 - probably has not gotten fixed.
Yes it is… @jordy1989 - it looks, at the moment, like importing just ‘Advanced Display’ will get the rendered mode - but checking all does not. Still poking…
Actually it looks like forcing a refresh is needed to see the change either way - maybe that is what you are reporting.
This is what I can reproduce so far-
RH-63242 OptionsImport: Display modes lag when imported
Hi @pascal ,
This bug also happens when i try to change settings in the display modes:
Any idea when these bugs are fixed?
Or is there a workaround to force a refresh?
Hereby a short example
        var rendered = Rhino.Display.DisplayModeDescription.FindByName("Rendered");
        rendered.DisplayAttributes.ShadeVertexColors = true;
        Rhino.Display.DisplayModeDescription.UpdateDisplayMode(rendered);
I gave it a bump…
RH-63853 is fixed in the latest Rhino 7 Service Release Candidate
