Feature Request: Ctrl+Shift Select - Can't Deselect
I believe it is still not existent. Would be nice to Ctrl+Shift+Select to select Geometry (surfaces, Curves, points…) and if you still press the keys and marquee select over an area that is already selected to deselect them.
Would made my day. I think this is the missing piece in Rhino’s overall selection.
Thank you
Is this what you are talking about?I think it can be done with Rhino8 WIP.
Selection: Ctrl(CMD) + window/crossing selection deselects sub-objects in command session (RH-69256)
Not sure but have you tried deselecting with just Ctrl pressed?
Martin, thanks but doesn’t work in V7
@martinsiegrist
Will look into it, thanks!
@11159
