Is this a bug?
can’t deselect the upper row of vertices to scale only the bottom ones
Thank you!
Is this a bug?
Thank you!
Hi Hannes - can you post the objects?
@pascal this is drag selection. It seems only to add objects, but you cannot deselect objects or points once selected. you know Ctrl+Shift Select
Maybe Rhino can be implemented this feature. Would help a lot.
Ah, yes - right, that does not work.
Press and hold Ctrl when windowing to remove selected objects from the selection.
Ctrl+Shift to add, Ctrl to remove.
I just tried it here to make sure I had the details right.
It works fine for me.
Are you pressing and holding Ctrl when you drag your deselection window over the selected items?
Yes I have tried both, does not work. so it’s Ctrl-Shift drag select. and in this mode I am only able to add more but not to deselect.
Clearly something is different then…
In Options > Mouse, is Method set to Combo?
In Selecting, are all 4 items checked?
I checked the forth one now I am able to deselect but it will deselect whole surface groups. I just wanted to drag deselect points. It is still not possible. ![]()
Thanks John
You may have to use the Selection Filter to make all of that work as you want.
Here’s a Mesh with Points turned on and selected (SelPts):
Here I have pressed Ctrl and dragged a selection window through the points to remove them:
It is subobject selection that does not work that way, as far as I understand the question, is that right @hannesgrebin ?
@pascal this is true. It is the subobject selection. It would be awesome to add this feature to Rhino. For easy selection and deselection on the ongoing prototype if I want to alter the object.
