I am not getting anywhere with this problem after several attempts.
When I extract the surface, the corners & edges remain empty. How can I now move the points on the edges so that they then intersect in the edge? That in the end looks like a trapezoid.
Thanks for your help, I have to finish the work today for school.
It’s not the best way of doing it, not fully parametric, because it uses Scale to get outer curves to loft.
Hope there is a way that can precisely control the thickness of the cells.
Thank you for the suggestion.
I have tried a few things with it. Unfortunately it only works as long as the scaling of all pages is identical. But in the height should not be scaled the same.
