I have a set of geometry on the right that I derived from voronoi. I am trying to recreate this geometry onto the left surface but I am having issues moving past the stage after getting the voronoi curves on the double curved surface.
I have made some progress but i cant get the final step right - in my original flat surface, the sdiff between the sphere and the extruded voronoi works nicely, but in my curved surface, some spheres work whereas others dont. Any advice would be appreciated on how to solve this!
Solid Difference requires closed Breps, which you don’t have here.
After trying to cut the surface to cap your extrusions, I finally went for Split Brep.
I also removed the unnecessary Patch calculation to retrieve the normal vector from the brep directly.
There is still a problem with the {70} branch. I’d look for simplifying the curves…
