Could someone help me extract a set of points on a surface for comparison, not control points. The “Point Set Deviation” tool works great but if I could copy the points or adjust density of the points taken that would be even better.
Thank you.
Thank you.
Hello- one way is to Mesh
the object and feed the resulting mesh to PointDeviation
rather than the surface - you can control the density of the mesh in the detailed mesh controls. By default, PointDeviation
uses the render mesh of a surface.
Thank you Pascal. That worked beautifully.
