Measuring a deviation from surface to surface
I have rebuilt a surface and I would like to measure if any deviation to the original surface has happened during my rebuild. In Alias I know the option “Locate Surface to Surface Deviation” (Image attached.)
Is there any such function in Rhino?
Using: Rhino 5 on a Lenovo P1, Windows 10
Thank you very much!
In Rhino 6 and Rhino 7 you can use PointDeviation. I don’t recall if PointDeviation in Rhino 5 works between two surfaces, or only between points or meshes and a single surface. You ExtractRenderMesh or ExtractAnalysisMesh from one surface and use PointDeviation to compart the extracted mesh to the other surface.
Hi David, thanks for your reply! Will try to do that. All the best to you!
