Hi Christopher - do you mean that Rhino resets the number you type, below .042, or that the number is what you say in Rhino but the printed thickness is never less than .042?
I can set the lineweight successfully to below .042 (e.g. 0.01) - it is displayed correctly, and when I export the geometry to .dwg or .ai the lineweight shows correctly in Illustrator.
However, if I print the layout to .pdf and then measure lineweights of the printed results, all lineweights are still correct (minor deviations, e.g. .13 becomes .127) except for the ones set to .05 and below.
All of them turn out to be .042.
Have you heard of this before?
Thanks, Christopher
Hi Christopher - I am pretty stupid about Illustrator but I cannot get the thing to show me anything but points for line weight… .099 for my .035 line from Rhino.
