When I export to PDF the PDF Does have the same placement of text in certain cases. Particularly the keynote number 1. In the pdf it shifts the number to the left and makes it not centered in the hexagon callout? I have attached the PDF and a screen shot from the layout detail window?
Also just wanted to mention, if anyone has an easy way to print out of Rhino, with no printer driver set up or if you have a good printer driver you can recommend, that would be awesome. Ever since I updated to the latest version of Rhino on Mac, the entire printer dialogue box has changed and become really sluggish and I can’t get any of my lineweights to show up when I open pdf in preview anylonger. That is why I am going this route of Exporting as pdf because at least I get my lineweights correct.
This changed when you updated macOS on your system.
We have tried to work around that macOS issue in the latest Rhino 7 version. A more thorough fix will come in Rhino 8.
Please run the Rhino SystemInfo command and copy-paste the result here.
Also please post a simple 3dm file that is not behaving well on your system.
