Help!
First -
I’m not sure when this occurred (looks to be a recent service release ) but the option to use “Save as PDF” from a printer selection has vanished and Rhino PDF is the ONLY means to get to PDF from the print dialog:
There used to be a Save as PDF dropdown if you’d selected a printer, which was a workaround for issues with RhinoPDF and now that’s gone.
In all other apps I get this when hitting print:
That would be ok if Rhino PDF worked but it’s got all kinds of problems:
On the left is the PDF output of the layout which is on the right. It’s fraught with errors, and YES Print display is ON for the layout window:
1 - Fonts rendering wrong. This is Monserrat-Bold. In some cases it renders right but in others it’s gong to a uber thin font (Doc User text for Area Room / Page Title, Page Number and a bunch of the labels are getting the “thin” font treatment as well, deplete using the the same text style.
2 - Colors are WAYYYY off. PDF of the field labels is WAY lighter than onscreen and actual prints.
3 - Some colors not rendering correct at all:
This sucks as I’ve got customer facing docs that are due, and have had to convert (essentially rebuild from scratch our AutoCad Title Block) to add a number of pages to an already existing file and I can’t even get the TB to render correctly.
PDF, 3DM and used fonts attached.
Sysinfo:
Rhino 8 SR10 2024-8-13 (Rhino 8, 8.10.24226.13002, Git hash:master @ c36ab43d576d4854b29b091b6b3a38e09decabf5)
License type: Commercial, build 2024-08-13
License details: Cloud Zoo
Apple macOS Version 12.6.1 (Build 21G217) (Physical RAM: 96GB)
Mac Model Identifier: MacPro5,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon RX 580 (8 GB)
LG HDR 4K - Left (3840 x 2160 @ 60.00Hz)
LG HDR 4K - RIght (3840 x 2160 @ 60.00Hz)
GPU Vendor: AMD
USB devices
VIA Labs, Inc. : USB2.0 Hub
ASMT: USB 3.0 Destop HD EP0 Product string
Generic: USB3.0 Card Reader
Broadcom Corp.: Bluetooth USB Host Controller
Kensington: Kensington Slimblade Trackball
3Dconnexion: SpaceMouse Enterprise
Apple, Inc: Apple Keyboard
Bluetooth devices
None
Third party kernel extensions
as.vit9696.Lilu (1.6.2) 264B15BE-8923-3A33-A9F5-8F0FFBB80595
as.vit9696.WhateverGreen (1.6.3) 9599C0FC-6144-3136-854C-C15FFF63706F
com.khronokernel.FeatureUnlock (1.1.2) 46C7C044-AE43-378A-8E50-F24BA68705DA
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.10.24226.13002
2024 Tabloid-Size Titleblock 1.0 a1 No Use Page Layoput Size .pdf (30.9 KB)
2024 BUGGY Tabloid-Size Titleblock.3dm (837.0 KB)
Fonts.zip (388.5 KB)
