simon9
(Simon)
August 7, 2018, 12:09pm
1
Hi guys,
I’m trying to export my 3dm project to dwg or dxf. But after exporting, only a wireframe mesh remains. All the surfaces are gone. Could someone help?
It’s something in either the export or import settings, because I just tried on another 3dm file and the same thing happens
3dm and dwg files can be found in this link: https://we.tl/vtEhwt3dtO
simon9
(Simon)
August 7, 2018, 4:21pm
2
I did some further testing, I believe it’s something to do with my export settings, but I can’t figure out what or where… I also don’t remember changing anything to the settings…
I normally always use export scheme “R12 Lines and Arcs”, which always used to work like a charm…
pascal
(Pascal Golay)
August 8, 2018, 3:19pm
3
Hello - the export for surfaces/solids needs to be set in the dwg export options - the 2004 Solids dwg export scheme should work.
simon9
(Simon)
August 9, 2018, 6:15pm
4
Hi ,
thanks for the feedback.
This scheme seems to work, thanks for the suggestion.
It’s weird though, I could have sworn I’ve always used R12 Arcs and Lines until now and never had this problem before.
Also “2004 solids” is the only scheme which exports solids/surfaces? Thats also seems weird to me?
