Exporting dimensions to .dwg - false units
Hello everyone,
Since Rhino 7, I have the problem, that my dimensions are always being exported to .dwg with the format of the model unit, although I have annotation styles where I changed the length unit formats from “Model units - decimal” to “Centimeters - decimal”.
For Example:
Document Properties → Model units → Units → Meters
Annotation Style “m”: Length Units: Units Formats: Model units - decimal (works always in .dwg export → appears as Meters)
Annotation Style “cm”: Length Units: Units Formats: Centimeters - decimal (doesn’t work in .dwg export → appears as Meters instead of Centimeters)
What is the solution, to keep the Units formats in the exported dwg file as in Rhino?
Hi Kemal - I see this, thanks.
it appears to be fixed in the V8 WIP.
