Hi guys!
I have a problem where I export a dwg sheet from Revit (units set to mm) and want to open it in Rhino. I open it directly (not using import as it doesn’t seem to bring the Revit sheet/layout) and for some reason even though I specify model units as mm and layout units as mm the rhino layout units always come in as inches. The scale of the layout viewport is somehow correct(Iish) though (eg the sheet is 1mm/500mm in revit and comes in as 1inch/500mm in the layout).
This is really annoying as to fix it I have the change the units in the rhino options then move the sheet to the correct place. It’s okay for a single sheet but if you want to do a whole set it is time consuming.
Has anyone come across this/knows how to fix it?
Thanks ![]()
