Export to Cinema 4D
what is the cleanest way to export to Cinema4d? Does anyone else use this workflow?
I tried OBJ, but my meshes get subdivided. DWG (which I used to use with FormZ) doesn’t form volumes.
It would be wonderful if I could preserve materials and layers.
I am somewhat desperate… any recommendations?
Thank you!
Georges
Export as .FBX. That will import fine in C4D and will keep material assignments. You may need to adjust some materials in C4D. Note: your layer structure will carry over to C4D, so best to keep good organization in Rhino. This workflow works really well.
