hello, i want to export a rhino file so i can import it in Revit, if i do that as a DWG file i have a problem synchronize the model with the central, the model is too heavy.
i have another way?
thank you
You can link a .3dm file into Revit natively.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-B69ED66A-4272-4332-9872-FD802DA1C9E7
Rhino.Inside.Revit lets you have more control what you bring in.
not sure if this article is up to date (@Japhy )
https://wiki.mcneel.com/rhino/architecture/bim/rhino-to-revit
Thanks Tom, it does need some updating, as do our guides. Trying to pick away at it, tough to keep up when you are adding components almost weekly as well.
