So a colleague I’m working with uses Archicad. He exported a 2D drawing as a .dwg. When I imported it into my Rhino 8.15, the drawing came in accurately, but some of the dimensions were completely wrong while others were correct? e.g. A vertical dimension of 10’ and another of 4’ came in as that, and measured as that in Rhino. A horizontal dimension of 79’-6" came in and became 7’-4"!! Truly weird. I wondered if Rhino was converting it to paperspace sizes but that was not the case. Thoughts?
have you tried changing the annotation style of the imported dims to one of your own inside of Rhino
Hi Nicholas -
Can you post a .dwg file that shows this behavior?
I’m not sure I can upload a file for NDA reasons. Here is what I discovered.
If I import the file with model units set to feet and layout units set to inches. The dimensions come as the were done in Archicad, (saying 86’-3") but in Rhino modelspace that 86’-3" measures 1034’-11".
However, if I import the file with model and layout units set to inches, the dimensions come in wrong, but the measurement in Rhino is correct. e.g. 86’-3" comes in as 7’-2", but in Rhino modelspace measures the correct 86’-3".
Here goes.
HOTEL.dwg (1.8 MB)
it looks like a scaling issue, (also what units was the original file drawn up in) if I import to one of my preset templates, scale it up then change the dims to one of my annotation styles, all good
Thanks for testing. He is working in imperial like I am. I was under the impression that .dwg files generally imported and exported without any need to do additional work when in the same units. If I remember correctly, my Autocad files did. Only my dynamic blocks didn’t work.
Ok Imperial, but what units, inches or feet ? It might be worth playing with Imperial units, hope you can get it sorted
(I often get lots of different files from all sorts of softwares, I still have issues sometimes, you’re not alone
DWG files don’t contain units, so…I mean if both parties are working in the same units in theory you might not have to do anything, but there are a lot of scales applied to a lot of things in different ways, so…
