Feature request: Export units choice
Hi all - I’m on a roll today.
I realize this must be rather niche - most civilized designers use one set of units, but I’m working on project in which our Rhino file is in mm, but the 2D CAD is in inches. So everytime I export, I then need to open the result, scale it, then import it into the DWG.
How hard would it be to have a scaling factor on export as a settings option?
The default would be no scaling, but we would have the option of creating an export configuration file in which user-specified factor gets applied? Or even better, the exact same list as is found in the “Distance” command?
Cheers,
Tom
Are you aware of *.dwg import options?
You can set the units right there…
Yes, I am very familiar with this.
I was asking for something similar when exporting, not importing.
