Hi everyone, I am having problems when I try to Export the display settings in Rhino 6. After the export the saved .ini is a 1 KB empty file that doen´t contain any information. Do you have any suggestions on what could be the problem?
Try use option export and while loading to the other machine use only display modes tick box.
Hi Stefano - could you provide more specific steps that you take? Do you get the same result for any of the display modes?
Also, as Piotr wrote, you can use the OptionsExport command to export all options at once - does this command work on your system?
Thanks for the reply. I think I found out the problem. Apparently Rhino doesn´t like to save this kind of files directly into our Server. If I save them in the desktop everything works how it should.
