Rhino.ExportViewDisplayMode Bug?
Hi @Dale,
Over here, both in Rhino 5 and 6 this method: Rhino.ExportViewDisplayMode will not export modes that use technical display pipeline (Technical, Pen, Atristic… plus any other being a copy of them). All other ones export ok and create the .ini file.
Do you see that on your end?
Also, if that doesn’t work - is there any other way with RhinoScript or Python/RhinoCommon to make it work in Rhino 5 as a workaround ?
thank you,
–jarek
Got it, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45489
– Dale
