Importing setting from rhino 5 to rhino 6
Is there a way to transfer all the settings I’ve made to the various display modes(>options>views>display modes) in Rhino 5 to Rhino 6?
Thanks,
Dennis
Use Tools \Rightarrow Export\;Options...
Then in v6 use the Tools \Rightarrow Import\;Options... entry. Make sure you import only the parts you are interested in (for instance autosave setting will otherwise change to v5 location).
You can also export individual display modes via Options>View>display modes…
However, I might be cautious about that, V6 display modes have changed a lot, and I seem to recall some people at least having some problems with modes imported from V5… maybe that has all been fixed though.
–Mitch
Thanks Mitch. What file do I import exactly. the default is a .ini file.
Yep, the individual display mode files as well as the general options files exported from V5 are all .ini files.
The section you want to import is Advanced\;Display. This imports all the display modes that are in the exported v5 .ini
Ah right, that was a good call. You best export and import modes one-by-one and verify everything still works as you expect. Let us know if it doesn’t.
