I am having an issue with the export of an IGES file. I divided a big model into different blocks, and when trying to export some of them the error: ‘A error while writing the plug-in file has occurre’ appears.
This only happens when I do not use the Predetermined IGES export set ups. The difference between my set ups and the the predetermined are:
=======IN POINTS AND CURVES=====
Max degree: 5
Curves defined as B-spline individual: ON
Use simple entities when possible: ON
Export normal of unity for normal curves: ON
=======IN SURFACES=====
Max degree: 5
use simple entities when possible: ON
Adust rational surfaces: ON
I am yet to find the core of the problem. And as mentioned, I can still work with the Predetermined Rhino set up, however it is not optimal for my application.
Any help would be appreciated.
