To see if a particular piece of the model was creating this error, I exported it in sections. This worked, but I am still unable to export it as a whole.
Any ideas as to why this is happening? And suggestions to get a clean output?
@Puja_Patel - it looks like your file got here OK - I am downloading it how.
Still downloading… that is a large file. IGES will likely be noticeably larger, since it is a text format, so make sure that the target location has the space.
I see the same problem you describe - I’ve sent it on to the developer for a look/
Have you made any headway on figuring out the issues we were having
exporting to .iges?
I’ve cc’d a Rishi Nandi on this chain who is also working on this on our
end. Please contact both or either of us if you have any questions.
Hi Puja - I have not heard back from the developer yet other than he speculates there may be a cap on iges file size, either in Rhino or in the format itself - that was just a question though, I don’t think either of us has seen such a cap. At any rate, he’s still poking at it. I’m not sure we’ve ever encountered the need to export quite such a large file to iges before.
@Puja_Patel - it looks like the format is indeed capped at 10 million lines - that is where the file stops writing. I guess you’ll have to do it in pieces…
