Do you know the possible reasons that the error “This package is not compatible with the Rhino Installer Engine” can occur?
I could install the plugin using the rhi file on 4/11 then added 15 lines of code and now this error comes up.
There is no problem when debugging, only when installing.
Is anyone able to help?
Kind regards,
Matthew Orwin
will
(Will Pearson)
2
Please have a look in %AppData%\McNeel\Rhinoceros\6.0\logs for the log file relating to your RHI file and share it here so we can have a look.
If you have Rhino 7 or Rhino WIP installed, then the log file may be under …\7.0\logs or …\8.0\logs instead.
Thanks, the issue seems to have resolved itself (not sure how), when I encounter this again I’ll upload the log file.
Thanks,
Matt
