Equation Driven Curves
How do you do this in Rhino? Is it more of a Grasshopper thing?
E.G. F(x,y,z)
Fx = Acos(t)
Fy = Bsin(t)
Fz = C*t
Yes, that’s a general form of a helix and there’s a Rhino command for that. Its just an example.
Thanks,
T
Hi @scrappydog1958 ,
import math
def create_helix(A, B, C, t_min, t_max, step):
    points = []
    t = t_min
    while t <= t_max:
        x = A * math.cos(t)
        y = B * math.sin(t)
        z = C * t
        points.append(rs.CreatePoint(x, y, z))
        t += step
    # Create the curve from the points
    rs.AddInterpCurve(points)
# Call the function with parameters
create_helix(A=5, B=5, C=1, t_min=0, t_max=10, step=0.1)
You can find the documentation here you can do pretty much anything Rhino - Rhino and Grasshopper Developer Documentation (rhino3d.com)
Farouk
Summary
[29€] My First Book: ML in Rhino with Real Examples (100% money-back) - News - McNeel Forum
Programming samples, simple and advanced, comes with working code. For beginners aimed at Machine Learning in Rhinoceros. In case you wanna learn check it out. :wink:
thank you so much.
T
Hello
here is one way in Grasshopper.
Up to you to see what suits you most !
