Equation Based Curves
I was wondering if Rhino has the capability to create an equation-based curve?
For instance, I want to create a curve (or fillet) using the exponentialequation: y=A*x^n
Where:
y= height
x= width
A= Constant
n= Constant
Hi Chase - not directly, no - it may well be something you could do in Grasshopper though.
Doesn’t MathCAD do something along those lines?
http://www.ptc.com/engineering-math-software/mathcad
Could you give me an idea of how to do it in grasshopper? I just started using GH about 15 mins ago…
Do you mean something like this?
plotgraph.gh (7.5 KB)
Yes that is exactly what I mean. Could you break down what all the modules mean? Sorry, but like I said before I’m very new to grasshopper.
If You know numerical values of the constants you can try this plugin
http://www.rhino3.de/_develop/__v3_plugins/math/
It doesn’t look like you downloaded the grasshopper definition that Arend posted - it’s best to just open that in Grasshopper to see what it does.
In short, you need to generate a range of x-values (I) and plug these into the function (II). That function will spit out the y-values and then both are combined to make points (III) and then a curve through these points (IV).
Wow thank you very much to both @wim and @arendvw
This is extremely helpful.
