Conversion from set of points to Curve (Not Nurb curve) and point for Grasshopper definition
const crvPoints = new rhino.Point3dList()
  let len = cpoints.length
  let zero = 0
  for(let i = 0; i< len - 2; i+=2){
    crvPoints.add(cpoints[i],cpoints[i+1],0)
  crvPoints.add(cpoints[0],cpoints[1],0)
  let epoint1 = (cpoints[len-2],cpoints[len-1],0)
  let epoint = [];
  let pt = "{\"X\":"+cpoints[len-2]+",\"Y\":"+cpoints[len-1]+"}";
  epoint.push(pt);
  const nCrv = rhino.Curve.create( false, 1, crvPoints)
  const crvData = JSON.stringify( nCrv.encode() )
  param1.append([0],[ crvData ])
  param2.append([0],[ epoint1 ])
  let trees = []
    trees.push(param1)
    //trees.push(param2)
    console.log(trees)
    RhinoCompute.Grasshopper.evaluateDefinition(definition, trees).then(result => {
        console.log(result)
rhino3dm().then( async m => {
  console.log('Loaded rhino3dm.')
  rhino = m // global
  RhinoCompute.url = "http://localhost:8081/" // Rhino.Compute server url
  RhinoCompute.apiKey = "" // your Rhino.Compute server api key
  // source a .ghx file in the same directory
  let url = 'curve as input.gh'
  let res = await fetch(url)
  let buffer = await res.arrayBuffer()
  definition = new Uint8Array(buffer)
I am not able to create a normal curve from a set of points in Javascript. Please suggest a solution for this.
Javascript?
What is a normal curve?
If you are just trying to make a polyline curve, then just Polyline, instead of a Point3dList, can then use Polyline.toPolylineCurve() to create your curve.
– Dale
