Hi Everyone:)
I’m trying to create an ellipse spiral with a consistent gap between the steps of the spiral that I can also control.
Thank you so much!
Michal
Hi Everyone:)
Thank you so much!
Michal
Simply scale the circular spiral in X or Y direction
Hi Seghier!
How can I do that? this is how I created my spiral…
Do you have a better idea of how to make it an elliptical spiral?
The i mage don’t show anything
Don’t you then get an inconsistant gap between the lines?
I’m trying to create an elliptical spiral, this one is a perfect circle…
I don’t understand what you mean
Ellipse is a scaled circle
A spiral more often is considered flat, 2D … but it can be also 3-dimensional, more correctly a “helix”.
Do you need a spiral (2D) or a helix (3D) ??
Hi Riccardo!
I need a 2D ellipse spiral.
Thank you but I nean a 2D ellipse spiral
Hi Riccardo!
A “constant gap” spiral is not really simple.
Even a normal “circular” spiral usually have the gap larger than the starting “step” input value, but still constant.
On an elliptical context this is even more complex.
Zoomed in you can see the inward offset (black) and outward offset (white) that doesn’t touch well.
@seghierkhaled … your first solution give high un-constant gaps.
Your second solution (by looping offsets) is probably the best possible without involving a really complex math/geometrical construction.
@michal2 if you need a elliptical spiral with “constant gap” I would go with the “loop offset” solution given by Seghier. You’ll need anemone.
Edit: even an Archimedean spiral does not have a constant gap…
spiral is when curvature is increasing thus collapsing to the center. helix is only in 3d . there can also be helix which is combined with spiral which is collapsing to the center in 3d
Hi everyone,
Wow cool! Thank you so much for all the info and solutions you shared!! it is very helpful for my project.
I think I will go with Riccardo’s solution because I would like to control the step’s size.
The looping offsets solution is also very good and simple!
Thanks again:)
