Create perfect spiral between two circles above eachother
i was wondering how i could make a perfect spiral between two circles above eachother. both circles are the same with the radius. I want to divide the circles and then make a spiral between. And i want to connect those divided points to eachother. So it will be a ramp that is circular. I used the component Nurbs curve, but that component doesnt make a curve perfect between the circles, but a little in between. I will attach the file.Test wokkel file.gh (21.8 KB)
Use Interpolate (IntCrv) instead.
Nurbs curve uses the vertices as the control points.
Edit: Actually Interpolate(t) gives a better result following the circles. The other one gives a slight deviation at the ends of the curve.
Test wokkel file_VME.gh (19.7 KB)
Here is another way usingPoint Cylindrical.
Test wokkel file_re.gh (12.2 KB)
Yet another way.
SPIRAL RAMP.gh (9.8 KB)
hello, how to make a pitch spiral of 3550 mm and 418º?
It is something that a client sent from an online program, but I realize that I do not know how to do this type of spiral.
http://www.zhitov.ru/spiral_stairs/
You can use polar array, move for each step and dome basics maths. I am sure there are scripts available for things like that.
l
Thanks and regards :wink:
Use this as well
spiral shape.gh (8.4 KB)
Hello I hope this is understood.
you just need to find the start of the Helix and then the spin number and use the native rhino command
thanks it seems to be what I’m looking for, but I still can’t make it work I think it is necessary to somehow extend the 58 degrees shown by the helix @vikthor
spiral shape.gh (8.1 KB)
see ↓
helix-418degree.gh (22.5 KB)
Check this
stair.gh (21.6 KB)
That solved it! Thank you very much! @vikthor
Thanks for the complement! I’ll be showing progress @anon39580149
This is an update
stair.gh (18.4 KB)
I see we share same group color preference :wink:
Other solution
spiral stair 2.gh (16.5 KB)
:slightly_smiling_face: thank you very much so I’m going
