Element Name Component from room elements
Hi @Japhy,
I am trying to query rooms and find out room element names using component.
I was expecting to get room names from the output, but I am getting Room numbers. I assume that I have to feed Name input to get the Name outputs correctly… Is that right?
Name outputs without the name inputs - return to room numbers
Name outputs with the name inputs - expected room names as outputs
You can find the attached GH file.
05_00_07_Room_Space_and_Area_Forum.gh (20.4 KB)
Thanks in advance.
Hi Junghwo,
Just getting to this, i was away from the computer last week.
The Element Name component is a Get/Set component.
You’ll want to use the Query Rooms and Element Parameter components if i’m understanding correctly.
Hi @Japhy ,
thanks for the reply. I wish you enjoyed your break from the screen.
Yes… that is right. I thought I could query the room names… jsut thought that “Element Name” component could give the room names from the room elements. Thanks again for clerifying it.
cheers,
Junghwo
