Select any Named CPlane. Restore CPlane is enabled
Click again to enable editing the text.
Click again anywhere else to end the text editing function-doesn’t matter if you edit the text or not.
The Named CPlane stays selected but the restore function is not available.
If you select another CPlane then go back to the original selection you can now restore.
I often want to restore a CPlane and edit the text too so this becomes annoying when you are working quickly. Not a big deal but fixing this would be much appreciated.
