I am trying to use ClippingDrawings to help improve the drawing process at work, but am running into problems with the way they display information. It’s rare that we would ever have a sectioned drawing that only displays the sectioned plane of an object, so I am almost always needing to make the background curves visible.
This creates a problem where edges on the back side of faces and objects on the other side of the object getting sectioned are being drawn. I’ve tried a couple different solutions to this but haven’t found one that is satisfactory.
There is an option to have the clipping plane generate surfaces for each sectioned object. I can then manually go through each layer and move objects in front or to the back. But this doesn’t work when I have everything in a layout and need to use wireframe display to print to a pdf with vector lines.
The consequences is that on complicated assemblies where the ability to semi-dynamically update drawings from a model would be most useful, the amount of confusing and erroneously displayed information make them basically unusable in a professional context.
Does anyone know of a work around for this problem? Is it a bug? Would really appreciate any advice. Thank you!
