according to fix
https://mcneel.myjetbrains.com/youtrack/issue/RH-77105
https://discourse.mcneel.com/t/rhino-8-feature-sectiontools-integrated/162094/138
i think need this option add to ClippingDrawings too
Can you please post the example file?
example ClippingDrawings.3dm (179.9 KB)
yes the example
@rajaa
I am looking into this issue, reported here…
@rajaa
@wim
And it was tested again in the new update(Rhino) (8.9.24156.10001, 2024-06-04)
and the new result: ![]()
New Test-example ClippingDrawings.3dm (274.4 KB)
true Fix: :in ClippingPlane
and False Fix: in ClippingSections
In some clipping situations, the back lines reappear
hi @rajaa again
seems Failure in removing lines behind clipping plane caps bug only when Projection=Parallel
in ClippingDrawings
test in :Rhino 8 SR9 2024-6-6 (Rhino 8, 8.9.24158.18001
cliiping parallel.3dm (392.8 KB)
