Lines in background showing on created drawings
Windows
Rhino 8
Hi guys I am struggling with background lines showing in my layout drawings. I understand that this may just be a limitation of the software and Rhino is doing exactly what I’ve told it to but its making producing architectural drawings quite hard as lines behind objects make for a confusing drawing.
Any help in solving this would be appreciated?
1 Fixed glass finished for forum.3dm (1.5 MB)
I create tons of layout pages, I often use the command ‘HideInDetail’ useful. I’m not sure exactly what you are trying to achieve but does using draw orders help with what you need-’SendtoBack’, ‘BringtoFront’ etc
Hi Stephen -
Thanks for that model.
I’ve put this bug on the list as RH-89147 ClippingDrawings: Background Edge Falsely Marked Visible
You can move the clipping plane to a different position to make that background edge go away. I haven’t found any position that triggers this and you’ll have to move it around a bit while watching the drawing update. In the model that I’ve attached to that bug report, I’ve created a rectangle, which center seems to do the trick.
Apart from that, you could use the clipped view of the 3D model directly to view and annotate in a detail that is set to a technical display mode.
Thanks Wim!
I had varying success with that, especially when I have a head and sill, one will show one won’t. Would you mind elaborating on this a little -
" Apart from that, you could use the clipped view of the 3D model directly to view and annotate in a detail that is set to a technical display mode."
I’m still new to Rhino, if you could explain that a little more that would be great.
Hi Stephen -
Here’s your file with a duplicated layout where all details reference the 3D geometry directly.
I didn’t recreate all annotations, but the ones that I made are all on the layout.
You’ll want to turn off hidden lines in the Technical display mode.
When you print this to vector PDF, all edges will be printed as vector lines.
→ 1 Fixed glass finished for forum-Fake2D.3dm (4.3 MB)
