Dynamic populate
This is my firist post her.
i have 2 close curves on the same plane originate from the same point.
I use Solid Difference and get a brep . i need to populate this brep.
I like to have the ability to decide the shape that populate all of the brep by changing the number of sides(Segments) of the shape(by using Number Slider). all of the brep is populate by the same shap/curves
And i also like to decide the a mount of shape ( by using Number Slider) inside the brep.
can it be done’ and how?
thank u
test.gh (14.4 KB)
trst1.3dm (51.4 KB)
Welcome to the forum.
Your .gh file is essential for understanding your problem correctly.
i update the first post and add the gh file.
thanks
like this?
test.gh (16.5 KB)
Thanks for the help, but that’s not really the intention.
I assume you were in the direction of connecting the Populate Geometry to Voronoi.
I’m looking for a way to populate the brep in same shap that allow me to control the number of Segments of the closed shape and the quantity. The more quantity I choose a larger number that will be created (of the same shape) but each of the shape wull be smaller in size/radius.
For example, if I chose 6 segments and a number of units of 10, the system will display 10 hexagons connected together and fill the brep
populate is a keyword in grasshopper, hence the confusion.
Maybe this helps:
I assume you like to tile the shape with Equilateral polygons.
Try these three, especially Honeycomb.
