V5
…So to click a curve and tell rhino all drawing is on the plane of that curve until I tell it otherwise would be so useful.
SetPt is a bit tricky as it asks for selection of the curve to which to bring the other curves, and if that curve is tricky to get to, and if I wish to join curves as I go, it would be easier to select a curve and indicate that all drawing is on the plane that curve is on.
Also if I am doinG a tan tan rad I get twists and elipses etc, I can turn on project and send everything to Cplane but then have to get it back to where it should be and also perspective view is of no use when the item is not where it should be as I draw it.
I dont want to be messing about creating named planes for each and every curve, aside from the fact I sometimes cant get back to the planes I was normally working with, and then I am in trouble.
Can that be done ?
Have wanted that since day 1 and V4 !
Cheers
Steve
