So I’ve been using the Curvature and draft angle analysis a lot.
I found the current tools very useful as well as limited, Is there a way to staircase the color ramp of this type of análisis?
It’s useful on curvature análisis and Draft análisis to understand different ranges of values. I know i can set up max and min values very close to each other to have that stair effect, but that would give me a binary result, i would like to see a 3 to 5 stepped color limits, right now i can only setup min and max values, but if i need to see, lets say, Min value of -1.5, values of 0, values and Max value of 5
Stepped Graph it’s useful when:
On Curvature Análisis (Min Radius specifically):
*Smallest Radius
*Target Radius
*No Radius
On Draft angle analisis:
- Negative Values
- 0 Degrees
- Target degree
