Curvature Analysis vs Draft Analysis UI
I know I’ve pointed out a lot of UI inconsistencies with Rhino already, but at least this one should be a very easy fix:
Hm… what is bugging you? These do two different things.
I think he wants to see the color distribution between the angles.
Similar to the scale between minimum and maximum curvature?
@Trav - what do you think - can we add the rainbow image ?
RH-58953 DraftAngleAnalysis - color gradient missing from dialog
Pascal
With the inconsistencies in the rest of the Rhino UI, what’s to say that the -5 angle isn’t the red color in the draft analysis?
It’s similar to the lack of U and V color coding that I’ve pointed out in other UI panels. I had to make my own icon and put it in a toolbar to remind me which was which.
@pascal please log a YT. This dialog had an image that appears to have vanished.
Ha, so it did!
There’s so many fixes in V7 WIP that I finally just switched… and now I get why it’s a WIP. :slight_smile:
This is from SR26:
Nice to see that some tools are getting expanded!
Is there a way to have an alternative Draft angle and Curfavure analysis gradient to replace the rainbow-coloured one? Like, a black&white gradient? For those of us who are colour blind and see certain different colours as if they are the same colour.
Having the option to have a stepped gradient instead of a smooth gradient is pretty useful as well, sometimes it is hard to interrogate draft with a gradient.
Going further, if you can have a stepped gradient with multiple bands, that would be useful for checking surface flow as well, especially now you can choose a draft direction within the tool.
Hi -
Now on the list as RH-58973: DraftAngleAnalysis: offer alternative gradients
Great! :slight_smile: Thanks!
This would be awesome. I would second the request on the issue tracker regarding stepped or banded color maps as well. A good source for color map options would be Choosing Colormaps in Matplotlib — Matplotlib 3.5.1 documentation
