Dear McNeel-Team
Referring to the help-file
_DraftAngleAnalysis the blue (left input field) value is the upper, the red value the lower value.
Either i do completely miss-understand the mapping of angles → color, or i would guess it s a bug:
see the follow series of pictures - i use a torus, part of a torus and two truncated-cone-like surfaces.
I would love to get more information about the two surfaces at the right and about their shared edge (kink) marked in the first picture:
Now i do a first Analysis from 80 (blue) 0(green) to - 80(red)
i interpret, that the surfaces are somewhere in the positiv sub-interval 0 to -80 / green to red.
i interpret that the edge that interests me is somewhere arround -40 (yellow)
this values also makes sense regarding the geometry:
In a next step i would like to have more precise info about the range, that is close to the shared edge entering a range from -10 as upper and -50 as lower, the entire surface is getting red.
i would interpret this as the entire surface is tilted more then -50 degree (what, of course is not true and does not make sense.
is it a bug ? or what did i miss-understand.
Thanks for your help.
Best Tom
