How to create parametric patterns in grasshopper
Hi, i wonder if anyone had done a pattern like the one used on this chair it would be awesome if this can be made with grasshopper, im trying to achieve a similar result.
It can. As a general rule, if you can do it manually you can do it in GrassHopper. But if it’s a one-off design you would preferably try doing it manually in Rhino at first, and then skip doing it again in GrassHopper. :slight_smile:
// Rolf
You can use tile or dash pattern with point or curve attractor, then map it to surface. Something similiar to this.
